Care and Maintenance of Toolholders
Worn or damaged toolholders can reduce tool life, degrade workpiece surface finish or harm the machine tool spindle. A downloadable guide from Techniks explains what operators should look for when evaluating the condition of a collet and nut-style toolholder.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/uploadedFiles/care-and-maintenance-of-toolholders-blog.jpg;maxWidth=600)
Collet and nut-style toolholders don’t have many components, but each one should be checked carefully for signs of wear or damage.
Techniks is a manufacturer of toolholders and accessories such as nuts, collets, retention knobs and many other toolholder and workholding products.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
