Dapra high feed cutting 4140ph at 300-ipm.
(sponsored content) Video: High-Feed Cutting 4140PH at 300 IPM with RHINO-FEED Mid-Feed Shell Mill and Inserts from Dapra.
This video demonstrates Dapra's 2" RHINO-FEED 5-flute Shell Mill and inserts executing a Z-level roughing routine in steel. The material is 4140PH, and the machine tool used is a Fadal 4020 with a 40-taper spindle.
This routine uses Dapra’s mid-feed inserts from the new RHINO-FEED product line. The inserts are 3/8” IC and offer 4 usable edges. Outstanding metal removal rates are possible on lighter duty machines using this method.
The parameters for this video are:
2” RHINO-FEED Mid-Feed Shell Mill
4140PH Material
550 SFM (1050 RPM)
.057" FPT (300 IPM)
.035" DOC
Variable WOC up to 100%
40 Taper VMC
Sandvik Coromant Launches New Range of Solid End Mills
The CoroMill Dura range is designed for roughing and finishing with different engagements in all applications and materials.
