Universal Workholding Solution Grips Challenging Parts
IMTS22: Norgren Workholding’s Adaptix can be quickly set up and grip unique parts for high mix, low volume orders.
Norgren Workholding demonstrates Adaptix, its unique universal workholding solution, which the company says can rapidly adjust to powerfully grip challenging workpieces. Adaptix’s innovative technology is said to ensure repeatability and precision are maintained throughout the machining process, resulting in more uptime and faster changeovers. Unique shapes can be quickly set up and held for high mix, low volume orders. Its ease of configuration and interchangeable pin tips mean machine operators can reduce set up and changeover times and associated labor costs.
Visitors to the Norgren Workholding’s booth can see the wide range of supporting system components such as tips and studs, which enable the product to adapt clamping forces and grip dependent on the material, as well as see Adaptix in action. Norgren’s team of application engineers will be on-hand to demonstrate Adaptix and to answer technical questions.
4-way Bed Precision Lathe Features Automated Cycles
Long and thin workpieces can be machined without reclamping on this new machine from Weiler, according to the company.
2022 Top Shops Honorees Announced
Modern Machine Shop recognizes excellence in manufacturing with annual Tops Shops awards.
Can Machining Simulation Propel Machining Education?
Digital twins prove their worth for not only proving out CNC programs, but also training the next generation of programmers.
