Two in One
Combining two separate and dedicated spindle motors in a single spindle housing enables these machines to perform high-torque roughing and high-speed finishing operations.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/twoinone-.jpg;maxWidth=600)
Switzerland’s Reiden Technik is new to the U.S. market. Its five-axis machine tools are available through Cincinnati, Ohio’s Pilsen Imports, which also offers large Toshulin vertical turning machines and Colgar horizontal boring mills.
Reiden has developed an interesting concept it calls Double-Drive Technology (DDT). This features two separate spindle motors in one spindle housing to enable its RX series machines to effectively perform both roughing and finishing operations. A hydraulic circuit is used to engage the high-torque spindle motor via a bevel gear coupling while the high-speed spindle motor freewheels. When the hydraulic circuit is off, the bevel gear on the high-torque spindle motor retracts to enable the high-speed spindle to be used. Learn more.
