Tooling And Accessories
A digest-size catalog from Eagle Rock Technologies contains tooling products and accessories, including chucks, collets, vises, knurls and more. Highlighted products include Knurlcraft, a selection of knurls and knurling tools for virtually any application; Wahlstrom Float-Lock fully automatic drill chucks and safety vises; heavy-duty Redmer air chucks; and Wettstein Tool specialty tooling for turning, milling and grinding. .
ANCA Creates Solid PCD-Tipped Helical End Mills, Drills
The company’s Edge machine is capable of creating complex 3D cutting tool forms, including solid PCD-tipped end mills and drills under 1 mm.
Kennametal Expands Modular Drilling Platform
The KenTip FS GTP insert allows for multiple machining applications across materials including steel, stainless steel and cast iron.
