Tool Management System Complements DNC
It quickly became apparent to this company that handling the many tools - knowing where the tools were and how many were available - was the horse, and the DNC system was the cart.
In 1997 when Camco Limited decided to replace an older minicomputer-driven distributed numerical control (DNC) system with a PC-based system, one thing led to another for this Belfast (Northern Ireland) subsidiary of Camco International (Houston, Texas). It became apparent that handling the many tools—knowing where the tools were and how many were available—was the horse, and the DNC system was the cart. “We realized we were setting assemblies that were moving from the tool room to the machine shop without any control,” relates Jim Heron, production engineer at Camco, a 200-employee shop that makes oil production equipment, such as safety valves and packers for oil wells. He says the company wanted to invest in a PC-based tool management system to see if it had too many of some tools and not enough of others and also to reduce inventory.
Unlike many other users, where costly events trigger the acquisition of a tool management system, Camco recognized that its DNC system would be complemented if it got tooling management under control. “We looked at a couple other systems,” Mr. Heron says, “but AutoTAS and DLoG seemed to work well together.” Camco did have an older tool store control system, but it did not provide tool monitoring to track the location of assemblies as AutoTAS from Micro Estimating Systems (New Berlin, Wisconsin) does. Rather, the older system let users view on a computer screen the quantity of a particular tool that was in stock. “That’s where it began and ended,” Mr. Heron says.
“We thought AutoTAS had greater potential and seemed to be more user friendly than most we’d seen at exhibitions,” Mr. Heron says. Also, he likes the modularity of the AutoTAS system. A company can install only the modules necessary for a particular task. Later, it can install other modules as they became necessary. Camco began with tool store control first. Next it began building tool assemblies and then evolved into data transfer to the machines, connecting AutoTAS to the DNC system.
The advantage of working with modular systems is not simply the reduced learning requirement at one time, nor the advantage of having fewer people involved with a new system. Modularity overcomes a major shortcoming of many non-modular systems: a frequent requirement that all data be present and all functions be operational, or no part of the system can be used.
“Actually, we started with quite a lot at once,” Mr. Heron says. “And as we were building all of that, others in the plant became interested, such as the gauge room and calibration areas.” Now, Camco’s QA department has also moved totally into AutoTAS gauge management and calibration. More recently, the company’s maintenance department added a seat on the stock administration side, and it is entering all spare parts for its machines into AutoTAS.
Camco’s technical buyer, Tom Dougan, is responsible for purchasing tooling. He worked closely with Mr. Heron setting up the AutoTAS item library, and he has become a real enthusiast for the tool management system. Today there are approximately 2,000 tools in the system. Mr. Dougan and Mr. Heron set all the tooling reorder points to enable the system to automatically produce requisitions. Mr. Dougan reviews the system daily and instructs the system to create orders. He and Mr. Heron then review the system’s suggested order(s) together before proceeding. AutoTAS can also generate a purchase order automatically. Today, if Camco Purchasing receives a requisition for any item still having a re-order card from the old system, the first consideration is whether or not the item can be entered into the AutoTAS system and the card thrown away.
Now, the company plans to extend use of the tool management system by linking it to a carousel storage system. The Belfast plant’s layout is well suited to a centrally located tool carousel outside the toolroom. The machine shop, assembly area and welding area are each adjacent to the planned carousel location. “The welding area has a stock of items now, as does the assembly department. We feel that a carousel near the tool room would be close enough for someone to walk from any of those areas to get supplies.” And that would bring a lot more supplies under control.
“If we put all of these supplies in the carousel under control of AutoTAS, people won’t be running short of tools any more.” Mr. Heron continues, “We can put the popular items in the carousel and set up the reorder points.” Having now operated a tool management system for almost 2 years, Mr. Heron knows it does far more than keep an accurate tool inventory. “Having a tool management system helps you look and see what you’ve got, and it helps reduce the inventory level of the tooling.”
Read MoreFrom Tradition to Transformation: Century-Old Manual Machine Shop Adds CNCs
After 122 years of working with manual mills and lathes, this fifth-generation shop acquired assets of a local CNC machining business and hired the owner. Here’s how it’s going a year later.
Read MoreSwiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
