Servo Feed Reduces Scrap When Stamping Circular Blanks
Fabtech 2017: Dallas Industries will feature its Zig-Zag servo feed for minimizing material scrap when running circle blanks.
Dallas Industries will feature its Zig-Zag servo feed for minimizing material scrap when running circle blanks. It has a one-, two- or three-out capacity, and the servo feed index cycle is made simultaneous with the cross-slide lateral travel, producing a diagonal stock movement in the automatic mode. The combination of the cross-slide lateral travel and diagonal stock movement minimizes the scrap generated when stamping out circles.
The manual mode has forward and reverse indexing and cross-travel indexing. The absolute feedback of the cross-slide eliminates the need for homing, so the feed is ready at power-up. The servo is mounted on a linear bushing support base that travels perpendicular to the stock flow on case-hardened guideways. It is designed to provide optimized strip advance and lateral length based on material width, blank diameter and web thickness.
STLE Opens Registration for 2024 Annual Meeting
The Society of Tribologists and Lubrication Engineers’ 2024 STLE Annual Meeting & Exhibition will take place May 19-23 at the Minneapolis Convention Center in Minneapolis, Minnesota.
Managing Coolant with Skimmers, Refractometers and More
Bacteria-infected coolant harms machines and sickens machinists. Coolant management technologies like skimmers and automated systems counter this tendency.
Vomat Coolant Filters Provide Precise Temperature Control
The company’s filters ensure a continuous supply of clean oil for microtool grinding applications.
