Product Spotlight Slideshow: Robots & Automation
View the slideshow to see highlights from January’s Modern Equipment Review Spotlight focused on robots and automation equipment.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/robotsautomationCollage.jpg;maxWidth=600)
Products from suppliers such as FANUC, Universal Robots, Fastems and TM Robotics (pictured) are featured in our January product spotlight.
The Modern Equipment Review Spotlight in our January issue focuses on industrial robots and automation. View the slideshow to see photos and learn more about the robotics and automation products we highlighted in print.
Using the Toolchanger to Automate Production
