Need For Change Brings Unexpected Benefits
This manufacturing company was faced with a dilemma common to many companies in today's manufacturing environment. Change their process to include CNC or lose valuable customers.
Eaton Corporation in Arab, Alabama, was faced with a dilemma common to many companies in today's manufacturing environment: change their process or lose valuable customers. Eaton manufactures motor controls with unique triggerhead geometry for various industries including those for power tools. One of their main customers made a decision to require all suppliers to accept only CAD data, exchange data via magnetic media, and to cut all parts using CNC.
This posed an immediate problem for the model shop because they had no CNC machines, and all of their parts were either created by hand or machined using manual machines. Adhering to this new directive would also involve a major process change. Eaton's current process involved using a model maker or die maker to generate the part, then completing it with some hand finishing.
Any jobs that could not be accomplished using this process had to be outsourced. Also, in addition to finished parts, their customers were starting to require Eaton to produce prototype parts quickly and accurately.
When they started looking for solutions, they had some major concerns because their product line contains some very detailed, small, tight tolerance parts. Some of these include trigger heads that measure 1 inch by 1 inch and are barely 1 inch in height. These also have many intricate nooks and cranies that require tolerances to 0.0005.
Eaton selected Acu.Carv (Olmsted Engineering Co., Traverse City, Michigan) for their CAM system. According to Jim Kemp of Eaton, they made this decision based on two main premises. One, the software was very intuitive, thus making it very easy to use, and two, the EDM module is designed for EDM and not a modified mill package. This means that a knowledge of how controllers function and their capabilities is built into the software, thus certain programming options are easily available and there is no editing of the G-code file required.
One of the options that Eaton liked was that, given a part file, they could quickly generate G-code for the true part geometry (without any offsets, wire diameters, and so on) without having to go through icons or parameter data changes. Also, once they became more comfortable with the control it was just as easy to generate a complete G-code file on the computer, including taper, gluestops, and automatic skim cuts. The software also provided an easy way of creating four-axis code without having to draw or receive the part data in 3D.
The learning curve was also very important to Eaton since they had very little CNC or computer experience. They first went to GFAGIECHilles for EDM training to learn the machine's functions and the capabilities of the controller. They also learned how to program parts manually on the controller. According to Mr. Kemp they were told by other area shops producing similar parts not to expect to be producing their complex four-axis products efficiently for three to four months or so. After contacting some existing Acu.Carv users, Eaton decided to start programming the wire EDM using Acu.Carv without attending training. Mr. Kemp stated that "After going through the tutorials and a couple of calls to Olmsted Engineering for support, we were producing production quality intricate parts within three days after returning from EDM training."
In addition to the dies, they produce many small molds that have deep straight wall cavities with many intricate shapes.
Prior to their purchase of the wire EDM and the software, they would produce these molds using a machine. Due to the small deep cavities there would be problems with arcing and inevitably they would lose two or three pieces before getting a good part.
Eaton now uses their wire machine to cut these parts. First they cut the cavity shape straight through the part. Next, they cut a plug out of another piece of metal the same shape as the cavity. The plug is then placed in the cavity to make the cavity the proper depth. Jim Kemp says that they can accomplish this because with the Acu.Carv/GFAGIECHilles combination they can hold the plug and cavity tolerances within a tenth thus creating screwless molds that provide many advantages over the old method. One is the time savings, up to 75 percent on these types of molds. Another major advantage is that this method creates a natural vent between the plug and cavity which allows gases to escape. This has added a crucial element to their manufacturing process and has led to more consistent parts.
Mr. Kemp stated that "Eaton has found that what at first looked like an uncomfortable situation has turned into a fortunate one in a very reasonable amount of time. We have been able to make full use of our controllers capability and reduce the amount of hand work and out-sourcing that we do. All this has resulted in better production and faster turnaround times. We would encourage anyone considering the same moves we made to give it a go." MMS
GF Machining Solutions Celebrates 70 Years of EDM Technology
GF Machining Solutions is celebrating the 70th anniversary of its discovery of EDM Technology.
Read MoreDielectric Oil Dramatically Reduces EDM Maintenance
Plagued by repeated small fires that interrupted its wire EDM throughput, this cutting tool manufacturer changed its dielectric oil and both eliminated fires and reduced its oil consumption.
Read MoreHybrid Control Makes Lights-Out EDM More Accessible
This CNC enables EDMs to switch between G-code and an integrated CAM system to adapt to changing conditions and make lights-out manufacturing more attainable.
Read MoreSmall Hole EDM Drill With Automation
The SY-4060 is a part of a lineup of CNC EDM drills from Belmont Equipment & Technologies.
