Multifunctional Table-Type Boring, Milling Machines
The Speedmat 2, 3 and 4 models comprise Pama’s multifunctional, table-type boring and milling machine range. The boring spindle is available in two different sizes, 130 or 160 mm, and table sizes range from 1,250 × 1,250 mm to 2,000 × 2,500 mm.
The Speedmat 2, 3 and 4 models comprise Pama’s multifunctional, table-type boring and milling machine range. The boring spindle is available in two different sizes, 130 or 160 mm, and table sizes range from 1,250 × 1,250 mm to 2,000 × 2,500 mm. Two independent, cast iron beds form a “T” configuration to support the movement of the column and the table. The machines are suited for the aerospace, heavy construction, diesel engine, die and mold, earthmoving, shipbuilding and power-generation industries.
Threading On A Lathe
