Monitoring Time for Preventive Maintenance Tasks
Not all maintenance tasks should be performed based on a calendar date. You can use a custom macro to monitor your machines.
Machine builders recommend preventive maintenance (PM) tasks that you should perform and the intervals at which you should perform them. Common tasks include CNC and encoder backup-battery replacement, air/oil filter replacement, way lube replenishment, hydraulic system oil replacement, coolant replenishment/replacement, and inspection and cleaning of key machine components, such as the spindle, way system and others.
It doesn’t make sense to perform certain PM tasks based on calendar dates since machines can often sit idle or be turned off for long periods of time. A more logical approach is to monitor certain PM issues on an individual basis, based upon specific criteria related to the machine function requiring maintenance. With spindle bearing inspection, for instance, spindle run time should be the determining factor.
Many modern CNCs do have comprehensive PM programs built in, and there are many software-based machine monitoring systems that can provide PM data. Some may allow you to specify intervals for the various tasks and even alert you when the interval has elapsed. However, with older FANUC or FANUC-compatible CNCs or if you want to take full control of a given PM issue, you can do so using custom macro.
Our example utilizes the custom macro presented in the May column. It makes an excellent way to monitor the passage of time, converting date and time into the number of hours since the beginning of 2019. Consider this command that calls the date/time converting custom macro:
- G65 P9060 D#3011 T#3012 H531.0
The current time in hours since the beginning of 2019 will be placed in permanent common variable #531.
Here are the variables used to track the four PM tasks for our example, based upon four different criteria.
PM Task: |
Interval: |
Started: |
Current Time: |
Monitored by: |
Battery change |
#521 |
#531 |
#541 |
Total elapsed time |
Change coolant |
#522 |
#532 |
#542 |
Coolant on time |
Inspect spindle bearing |
#523 |
#533 |
#543 |
Spindle on time |
Inspect way system |
#524 |
#534 |
#544 |
Machine in-cycle time |
Specifying intervals
This program can be run once to specify intervals for PM tasks based on machine builder recommendations:
- O0032
- #521=8736.0 (replace CNC battery)
- #522=3000.0 (change coolant)
- #523=6000.0 (inspect spindle bearings)
- #524=5000.0 (inspect way system)
- M30
Initializing
Another program is needed to initialize the system and to reset the monitoring variable for PM tasks when they have been completed. After performing maintenance, the operator must scan to the appropriate sequence number for the task to reset. N1: Battery replacement, N2: Coolant change, N3: Spindle bearing inspection, N4: Way system inspection.
- O0033
- N1 (Reset battery time)
- #541=0
- M30
- N2 (Reset coolant change time)
- G65 P9060 D#3011 T#3012 H532.0
- #542=0
- M30
- N3 (Reset spindle bearing time)
- G65 P9060 D#3011 T#3012 H533.0
- #543=0
- M30
- N4 (Reset way system time)
- G65 P9060 D#3011 T#3012 H534.0
- #544=0
- M30
Updating
Machine functions require different updating methods.
Battery change: We can update total elapse time every time a program is run by using a user-defined M code for the end of program word: M30.
Coolant change: We can update coolant-on time in user-defined M codes that turn the coolant on and off (M08/M09).
Spindle bearing inspection: We can update spindle-on time in user-defined M codes that turn the spindle on and off (M03/M04/M05/M19/M06).
Way system inspection: We can update in-cycle time in user-defined G or M codes that are executed only at the beginning and end of the program, like G20/G21 and M30.
User-defined G- and M-code programs
These programs will run when the designated G or M code is executed. A parameter specifies which G or M code is related to each program. With current FANUC CNCs, parameter 6071 specifies the value of the M code that will execute program O9001. If you set parameter 6071 to 30, for instance, the CNC will run program O9001 whenever an M30 is executed.
- O9001 (M30)
- G65 P9060 D#3011 T#3012 H141.0
- #541=#141-#531 (Current total elapsed time)
- #544=#544+[#141-#140]
- M30
- M99
- O9011 (G20 or G21 at program start)
- G65 P9060 D#3011 T#3012 H140.0
- G20 (or G21)
- M99
- O9002 (Coolant start M08)
- G65 P9060 D#3011 T#3012 H142.0
- M08
- M99
- O9003(Coolant stop M09)
- G65 P9060 D#3011 T#3012 H143.0
- #542=#542+[#143-#142]
- M09
- M99
- O9004 (Spindle start M03 or M04)
- G65 P9060 D#3011 T#3012 H144.0
- M03 (or M04)
- M99
- O9005(Spindle stop M05 or M19 or M06)
- G65 P9060 D#3011 T#3012 H145.0
- #544=#544+[#145-#144]
- M19 (or M05 or M06)
- M99
Monitoring and testing
Finally, there must be a way to alert maintenance personnel when a PM task is required. You could place the detection sequence in machining programs, but to keep from disrupting a production run, it may be better to create a separate program. The operator or a maintenance person will run the detection program when they want to find out if PM tasks are required.
- O100 (Detection program)
- IF[#541LE#521] GOTO 5
- #3000=101(REPLACE BATTERY)
- N5 [IF#542LE#522] GOTO 10
- #3000=102(REPLACE COOLANT)
- N10 IF[#543LE#523] GOTO 15
- #3000=103(INSPECT SPINDLE BEARINGS)
- N15 IF[#544LE#524] GOTO 20
- #3000=104(INSPECT WAY SYSTEM)
- N20 #3000=105(NO MAINTENANCE REQUIRED)
- M30
Swiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
Read More5 Reasons Why You Should Know How to Write Custom Macros
Custom macros enhance what can be done in G-code programs, giving users the ability to code operations that were previously not possible.
