Workholding from Mate Precision Technologies
Mill like a Virtuoso
Your machining center is a sensitive instrument.
Your machining center is a sensitive instrument. The process that makes use of that machine can be “tuned” to run better—literally to run more harmoniously—in very much the same way that a musical instrument can be played with finesse. The problem is that the subtle steps necessary for tuning a machining process aren’t practical for most shops.
However, what if there was a “maestro” available online?
Researchers are now developing this utility that might soon be used to make almost any milling process more economical and productive.
Just how much will machining change if any shop can have easy access to “sweet spot” milling parameters that are tailored to that shop’s very own machining processes?
Mate Workholding - Accuracy and Repeatability
RazorStar
Mate Workholding - No Interruptions or Surprises
