Drill-Tap, Mill-Trim Three-Axis Machining Cells
Zagar’s multi-axis machine station is designed for automatic production drilling and tapping as well as light milling and trimming.
Zagar’s multi-axis machine station is designed for automatic production drilling and tapping as well as light milling and trimming. Use of standard, modular components enables application-specific X- and Y-axis travel lengths. Ballscrew actuated, quill-feed units are applied to the cutting tool feed or Z axis with optional 6" to 14" travel lengths and 1- to 15-hp spindle motors. To view video about the machine station, visit zagar.com.
ANCA Creates Solid PCD-Tipped Helical End Mills, Drills
The company’s Edge machine is capable of creating complex 3D cutting tool forms, including solid PCD-tipped end mills and drills under 1 mm.
Tungaloy Expands Drill System With Drill Sleeves
Adding drill sleeves to the standard lineup enhances drilling productivity of Swiss-type sliding-head automatic lathes.
Walter Extends Line of Precision Boring Tools
The new boring tools employ modular components such as cartridge holders and extensions, which are matched to the system, utilize an extensive range of indexable inserts suited for precision boring and can be used for all material groups.
