How to Choose the Right Bench Comparator Stand
Understanding a comparator gage’s features and characteristics will help you choose the right one for your application.
A bench comparator stand is not a very complicated device. If you go to choose one, however, you’ll find there are hundreds of options, sizes and levels of quality. In selecting the right stand, it’s important to understand your application thoroughly to make sure you get enough capability for your needs. With a little upfront work and by asking the right questions, you will end up with faster, easier, more accurate measurements, and spend less time on repairs and adjustments. It may take just a little more planning, but you’ll come out ahead.
A bench stand consists of an indicating device plus a post/arm assembly mounted to a base that incorporates a locating surface for the part. In contrast, a post/arm assembly with an indicator and no locating surface for the part is known as a test stand, and it must be used with a surface plate. And this is not to be confused with a bench thickness gage that has the locating surface for the part and an indicating device but does not have the flexibility of the arm/post arrangement. It’s important to understand the stand’s capabilities, features and options, as choosing a stand with features that do not meet your comparator needs can create lots of problems.
The first two considerations in selecting the right comparator are the size of the part to be measured and the tolerance of the dimension to be checked. The types of stands described above each incorporate an arm/post/base, which is really the backbone of the gage. The structure that holds these three parts together in a rigid manner forms the shape of the letter “C.” In some cases, this may be hard to see, but there really is a “C” in every gage. The more mass in this “C” structure, the better the stability of the gage and the stiffer the moment of movement. Thus, it is pretty clear that the tighter the tolerance, the more mass you will want in the gage, whether the part to be measured is large or small. The “C” frame is the base on which the measurement is taken. You may have the most accurate indicator or probe available, but if it’s mounted to a frame that flexes and twists, it just won’t pay off.
On some stands—especially those used to measure large parts—the base itself serves as the reference surface. Bases may be either steel or granite, with steel being easier to lap flat when necessary. For higher accuracy, it is usually desirable to use a comparator stand with a steel or ceramic anvil mounted to the base. As a smaller component, the anvil can be machined to a tighter flatness tolerance than the base, often to a few microinches over its entire surface. Some anvils have diagonal grooves milled into the reference surface. These serrations serve to wipe any dirt or chips off the part, and reduce the contact area across which contamination-induced errors may occur. Or, in the case of very light parts, the serrations can actually keep air from getting under the part and influencing the readings. In some cases, the anvil may be so flat as to provide a wringing surface for the workpiece, an excellent circumstance for very critical measurements. The anvil is also easier to keep clean and can be more readily adjusted to squareness with the indicator.
The post should provide some kind of support for the arm beyond the arm’s own clamp. Without it, you risk dropping the arm every time you loosen the clamp to adjust the height, which could result in damaged components and crunched fingers. At minimum, there should be a locking ring on the post. A better approach is a rack-and-pinion drive, which makes it much easier to position the arm, especially if it’s heavy, and even these should be equipped with their own locking mechanisms so that the weight of the arm does not constantly rest on the drive screw. In some cases, the “post” may be a dovetail slide, which eliminates rotation of the arm in the horizontal plane. This can make setup easier when the anvil remains the same, but the arm must be raised or lowered to measure parts of different lengths.
When it comes to the arm, shorter is better to minimize flexing, although a longer arm may be needed for larger parts. A fine height-adjustment screw is a valuable feature for accurate positioning of the indicator relative to the part. Also, look for a good locking device that clamps the post to the arm across a broad surface rather than at a single point, as this could allow the arm to pivot up and down. An axial swiveling feature is available with some arms for special positioning needs.
Now that you have selected the stand with the best size and mass for the part dimension to be measured and made sure that it has all the features for fast reliable measurements, it’s time to think about the interface to the user: the readout device. This is a topic for another column, but it is safe to say that this is also a critical component for ease of use and proper results.
The bench comparator stand is often thought of as the universal gage when parts can be brought to it. Taking into account the proper features of the stand for the application can make a universe of difference in the type of results obtained.
Speeding Up Splines
Moving small- to medium-batch production from outsourced, dedicated hobbing operations to in-house, CNC multitasking machines helps job shops achieve quick turnarounds and flexibility in supplying splines for the heavy-vehicle industry. Inserted disc cutters make this transition possible.
Read MoreSelecting The Right Welder
Many machine shops, on occasion, have a need for welding. It may be for maintenance purposes, repair or to fill the odd contract. This story is a welding process primer for those shops whose main business isn't welding but need to know some basics.
Read MoreUnderstanding The Four Major Behavioral Styles
Companies today are expanding the role of teams in the workplace in an effort to empower employees and improve organizational effectiveness. The more we try to work as a team, the more important it becomes to recognize that people exhibit different behavioral styles.
