A New Formula for Metal Removal Rates in Turning
An expert on cutting tool theory and practice is proposing a new formula for calculating the metal removal rates in turning operations. This formula factors in the diameter of the workpiece to yield more accurate results and lead to better decisions about productivity.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/sandvik5.jpg;maxWidth=600)
Edmund Isakov, PhD, a well-respected expert on cutting tool theory and practice, is proposing a new formula for calculating the metal removal rates in turning operations. Dr. Isakov is a proponent of this formula because it factors in the diameter of the workpiece to yield more accurate results. The new formula will help manufacturing engineers make better decisions about productivity.
Tungaloy Expands Threading Tool Insert Offerings
The TungThread indexable threading tool series is designed for applications including general parts that are machined in CNC lathes and small precision parts in Swiss-type automatic lathes.
Tungaloy Expands Turning Tool Lines With Left-Handed Inserts
The TCS18 and TCL18 inserts are designed for left-hand cuts, expanding product lines that previously offered only right-hand inserts.
Sandvik Coromant Turning Tools Enable Y-Axis Turning
The company has developed two new tools to support Y-axis turning: CoroTurn Prime and the CoroPlex YT twin-tool.
