Robots Assist with Repetitive Tasks
January’s Spotlight product curation focuses on robots and other automated machining and work handling equipment.
While the topic of robots and automation continues to spur intense development, innovation and debate, there’s no denying that robotics shine when applied in situations with repetitive tasks, such as load handling in production runs. A few of this month’s curated robot and automation products suit this sort of implementation. A different sort of application is exemplified by Perceptron’s AutoScan Collaborative RoboGauge, which performs automated 3D scanning by combining a FANUC robot with Perceptron’s Helix scanner.
Click the image above for a slideshow featuring these and other automation products, with links to more information.
3 Ways Artificial Intelligence Will Revolutionize Machine Shops
AI will become a tool to increase productivity in the same way that robotics has.
Using the Toolchanger to Automate Production
