3D Testers Designed to Withstand Damage from Splash Water/Oil
Euro-Tech’s line of Tschorn 3D testers are designed to remain wet in the toolchanger, resisting any damage from splash water and oil.
Euro-Tech’s line of Tschorn 3D testers are designed to remain wet in the toolchanger, resisting any damage from splash water and oil. The Tschorn SlimPlus 3D tester is certified with IP67 and said to be slimmer than the competition. According to the company, probing is possible for the SlimPlus in all axes directions at the same indicator resolution. As soon as the indicator is at zero, the vertical axis is directly on the edge of the workpiece.
5 Tips for You To Get the Most From IMTS
Plan, explore, think of the future: Here is how to get the most from the major manufacturing event that none of us have experienced in four years, and that many will be experiencing for the first time.
4-way Bed Precision Lathe Features Automated Cycles
Long and thin workpieces can be machined without reclamping on this new machine from Weiler, according to the company.
