3D-Printed Metal Device Enables More Accurate Surgery
Additive manufacturing made it possible to cost-effectively produce a medical device to help surgeons in ACL repair and replacement surgery.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/3DPrintedMetalDeviceEnablesMoreAccurateSurgery.jpg;maxWidth=600)
Surgery on the anterior cruciate ligament (ACL) in the knee is a complex procedure that demands precision and control. In order to repair or replace an ACL, the surgeon removes any remnants of the natural ACL and then attaches a replacement ligament (a graft usually taken from elsewhere in the patient’s body) to the tibia and femur. The positioning of the grafted ligament is critical, as it should accurately mimic that of the natural ACL.
To help make this precise surgery easier, orthopedic surgeon Dr. Dana Piasecki designed a two-part system consisting of a flexible pin (drill) and a guide for positioning the pin inside the knee. This guide is the key to a less invasive surgery, as it allows the surgeon to move and hold the pin without opening the knee or contorting it to place the new ligament.
Though 95 percent of the guide is made up of a simple shaft, the end of the device is the critical part. The shape of the neck is intended to follow the ligament’s normal path to ensure that it is placed at the right location and angle, and the tip is precisely sized to hold the 2.2-mm pin.
To machine this guide tool from a block would have required many setups with multiple angles and undercuts. Instead, Dr. Piasecki and his business partner Jim Duncan of DanaMed worked with Stratasys Direct Manufacturing to have the device manufactured with direct metal laser sintering (DMLS). This powder-bed additive process allowed the device to be built at the correct angle and build orientation to accommodate the critical features, without any machining necessary. Producing the guide additively also saved on material and reduced its overall cost, while enabling ongoing design changes.
Learn more about this device—including its design, manufacture and postprocessing—in this article from Additive Manufacturing magazine.
EDM, Laser Micromachining and More at GF Medical Demo Center
At GF’s Medical Center of Competence, the company shows off EDM and laser features that could make a large impact on medical manufacturing — and elsewhere.
The Producto Group Appoints New Member to Board of Directors
Dean Schauer, the newest appointee to the company’s board of directors, is the current CEO and president of Confluent Medical Technologies.
Ametek EMC Laser Cutting System Offers Through-Part Cooling
The new laser cutting system offers comprehensive Swiss machining capabilities, as well as through-part cooling and automatic part-handling options.
