Product Slideshow: Turning
Lathes and turning machines designed for flexibility are highlighted in this month’s product spotlight.
This month’s product spotlight highlights turning equipment—lathes, turning centers, mill-turn machines and even a CNC specifically designed for turning. Many of the turning machines covered have features designed to make them more flexible. For example, the EcoTurn 650 turning center from DMG MORI can be equipped with an optional C axis for turn-mill machining. Meanwhile, the Hwacheon VT-1150 vertical lathe has a geared drive system that enables high-torque turning at low speeds as well as high-speed turning. Click the image above to access the slideshow featuring these machines and more.
