End Mill Series Extends Lengths of Cut, Corner Radius Options
M.A. Ford has expanded its TuffCut XT Series 278 range of end mills with more than 400 new product variants.
M.A. Ford has expanded its TuffCut XT Series 278 range of end mills with more than 400 new product variants. Featuring the company’s Altima Blaze coating, these five-flute, high-performance, solid carbide end mills provide high metal removal rates and are designed for use with steels, stainless steels, special alloys and cast irons in a range of industries.
Covering diameters ranging from 0.125" to 1.000" as well as metric sizes, the extended series provides additional lengths of cut, through-coolant capability and Weldon flats shanks as well as increased corner radius options designed to meet the needs of the aerospace industry.
Features such as enhanced edge protection, CNC-ground uniform tooth width on all flutes, face grinding on square-corner-cutting tool profiles and blended neck relief are all retained within the range from the original design, which enables the end mills to perform better and last longer than competitive products, the company says. These features minimize process downtime while maximizing productivity.
Ceratizit Expands Range of Indexable Milling Tools
MaxiMill 491 features eight cutting edges per newly expanded 9-mm insert size, a precise 90° profile and a durable, nickel-coated tool body.
10 Tips for Titanium
Emuge-Franken End Mill Wins ANCA's Tool of the Year Award
Emuge-Franken received the award for its specialized tool based on the new Cera-Cut end mill design.
