Valve Production Machine with 20-inch Turning Capability
Mazak offers its Orbitec 20 for manufacturers of valves and similar large components.
Mazak offers its Orbitec 20 for manufacturers of valves and similar large components. Well-suited for manufacturers in the energy industries, this machine is said to be a cost-effective valve body production center that completes more than 75 percent of valve applications in brass and steel in one setup while maintaining high tolerances. It is able to complete a variety of valve features, including the facing of flange surfaces, conical boring of taper holes, face milling and end milling. This video, taken at Mazak’s Southwest Technology Center in Houston, Texas, show the Orbitec machining a demonstration valve component.
The Orbitec 20 features 20-inch-diameter turning capability and has a proprietary facing head. It is equipped with a 40 hp, 600-rpm integrated spindle motor and offers axis travels of 11.8 inches in X, 23.62 inches in U, 23.62 inches in V and 48.43 inches in Z. A two-pallet changer option is available.
Large-Format Machining Simplifies Tube Manufacturing
Downtime is the enemy of efficient manufacturing — a problem FIBA Technologies has addressed through purchasing a Soraluce FLP 14000.
Four-Axis Horizontal Machining Doubles Shop’s Productivity
Horizontal four-axis machining enabled McKenzie CNC to cut operations and cycle times for its high-mix, high-repeat work — more than doubling its throughput.
The Job Shop Is the First Half of the Business
By day, NTL Industries went from a lathe and a mill in a home garage to an 11-employee enterprise in under five years. By night, it tackles a new future.
