Hole Making: Combination Tools
This video demonstrates hole making. Hole making often involves sequential operations such as drill-then-tap. Combination tools that perform these operations simultaneously can eliminate tool changes, saving cycle time. Many combination tools call for helical interpolation. The video shows the same series of hole
Video shows the same series of holes machined first through drilling then tapping, then though drilling and tapping using a combination tool. Footage courtesy Mazak.
The video shows the same series of holes machined first through drilling then tapping, then though drilling and tapping using a combination tool. Footage courtesy of Mazak.
How Lowering Torque Improves Tapping Tool Life
Escaping the tap breakage trap requires a long look at torque and the many factors that influence it.
Tungaloy Expands Drill System With Drill Sleeves
Adding drill sleeves to the standard lineup enhances drilling productivity of Swiss-type sliding-head automatic lathes.
Form Tapping Improves Tool Life, Costs
Moving from cut tapping to form tapping for a notable application cut tooling costs at Siemens Energy and increased tool life a hundredfold.
