Valve Machining Video…Finally
Check out video of this interesting valve production machine.
The Orbitec 20 is geared towards manufacturers of valves and similar large components. Well-suited for manufacturers in the energy industries, this machine is said to be a cost-effective valve body production center that completes more than 75 percent of valve applications in brass and steel in one setup while maintaining high tolerances. It is able to complete a variety of valve features, including facing of flange surfaces and conical boring of taper holes. Capabilities also include face and end milling.
Horizontal Turning Center Ready for High Production
Romi Machine Tools’ new GL300 S features high-power torque and feed force and is built with a robust monoblock base for ultimate rigidity and precision.
Horizontal High-Speed Machining Saves Hundreds of Work Hours
High-speed machining is the latest change at Blair-HSM South, helping this once old-fashioned shop improve productivity and morale while enabling new work.
