Okuma
Turning to an Alternative for Small, Complex Work
The QuickTech TT-42 from Absolute Machine Tools provides many of the same advantages as a Swiss-type lathe for small, complex parts that don’t justify the use of a guide bushing.
Loading the player ...
As shown in this video, the TT-42's configuration enables users to maneuver cutting tools very close to the work, which helps avoid rigidity issues with small parts. The machine also provides the multi-function capability to machine parts complete in one setup, even to the extent of cutting two complex components simultaneously on either spindle.
When Mark Schubert first laid eyes on the QuickTech TT-42 turning center he’d soon be selling for Absolute Machine Tools (Lorain, Ohio), the first potential customers that came to mind were users of Swiss-type lathes. That might seem odd, considering the Swiss-type has proven itself as a go-to platform for producing small, complex parts in one setup—the same role envisioned for the TT-42. However, Mr. Schubert contends that rather than stepping on Swiss-types’ toes, this dual-spindle, 8-axis turn-mill fills an important, complementary niche: parts that don’t require a guide bushing, yet aren’t suitable for production on smaller turn-mills.
The guide bushing is the defining feature of a Swiss-type. By supporting the barstock very near the point of the cut, it provides the rigidity required to precisely machine long, slender parts without deflection or vibration. In the field, however, these machines tend to be valued equally as much for their versatility, says Mr. Schubert, who sells Swiss-types from Star (Roslyn Heights, New York) in addition to serving as a regional vice president of sales for Absolute. He notes that many customers use their Swiss-types’ subspindles and live tools for fast, single-setup machining regardless of whether the part is long enough to benefit from a guide bushing.
However, this strategy comes at a cost, Mr. Schubert explains. First, Swiss-types tend to require a larger up-front investment than conventional fixed-headstock turning centers. Second, barstock must meet certain straightness and diameter tolerances to fit within the guide bushing. With typical clearances of only 0.001 inch between the stock and the bushing, using anything other than costly, centerless-ground bar can result in out-of-round conditions, poor surface finish and other problems.
That being the case, a small, conventional turn-mill might seem to be a more cost-effective choice for parts with length-to-diameter ratios that don’t justify the use of a guide bushing. After all, many fixed-headstock turning centers with subspindles and Y-axes offer all the multi-function versatility of a Swiss-type. However, the slant-bed construction that is typical of such machines can cause clearance issues with smaller workpieces and cutting tools, Mr. Schubert says.
To approach the work at the proper angle, these machines’ tool turrets or spindles must be mounted to the slanted bed with a cross-slide or other apparatus. This introduces extra mass that, in addition to the bulk of the turret or spindle itself, can interfere with the close-quarters machining required for small, complex parts.“On a slant-bed with a turret, getting, say, a 1/8-inch-diameter end mill close to a small part may cause interference between the tool and the chuck,” Mr. Schubert says. “You’d have to extend the tool itself or extend the part further out from the chuck to maintain clearance, but that can create problems with rigidity.”
In contrast, the TT-42 employs a flat-bed design with dual, live-tool gang slides on a vertical plane that move the X, Y and Z axes, just like those on a typical Swiss-type. Complete with a subspindle and backworking tool posts, this configuration enables users to maneuver cutters close to the stock for rigid, multi-operation machining of small parts without clearance issues or the need for a guide bushing, Mr. Schubert says. He adds that eliminating the additional bulk associated with Y-axis-equipped slant-bed designs improves operator access to the workzone. In fact, he estimates this configuration reduces the distance between the door and the spindle centerline by approximately 20 percent compared to a similarly sized slant-bed machine.
Various options are available to enable the TT-42 to take on a wider range of work. For example, electric spindles from Ibag (North Haven, Connecticut) can provide speeds ranging to 60,000 rpm, as opposed to the standard 6,000 rpm. Likewise, a B-axis option enables the gang tool slides to swivel ±45 degrees for contouring or angled drilling operations.
Still, Mr. Schubert emphasizes that the machine’s role is application-specific. Misapplying it entirely is just as likely as overlooking its capabilities. “By no means does the TT-42 do Swiss turning,” he explains. “Parts of a certain length-to-diameter ratio are always better suited for a Swiss-type. Nor does it have the horsepower for heavy milling work, like a conventional turn-mill might. This machine is a hybrid.”
Okuma
MMS Top Shops
Gravotech
Turning Tools
Buying a Lathe: The Basics
SPONSORED
Turn/Mill
Vertical Machining Centers
Okuma
