Titanium Calls for a Tight Hold on the Tool
Haimer’s SafeLock System provides pull-out protection for tools in high performance cutting such as the machining of titanium.
Meeting the challenge of machining titanium effectively is the focus of many machine tool builders and cutting tool manufacturers. A common theme is “no missing links.” That is, a shop needs the right machine, cutting tool, programmed tool path, workholding setup and coolant delivery system to master titanium machining. Brendt Holden, president of Haimer USA (Villa Park, Illinois) would agree, except he’d add one more critical link to this chain of required elements—the right toolholder. Haimer USA’s parent company in Germany has developed a system specifically designed to address one of the problems encountered when applying high-performance cutting to titanium and other tough alloys. This system, called SafeLock, is designed to prevent a cutting tool from loosening and being pulled out of its holder. This situation could potentially scrap a very expensive aerospace part.
"Crazy" Tools from Mikron Expand Capabilities
Despite past challenges of the pandemic, Mikron Tool's R&D department runs at full speed, developing efficient machining of demanding materials in the micron range.
10 Tips for Titanium
