The Challenge in Capturing Liquid Smoke
Machining hard metals with straight-oil coolant can generate “liquid smoke” that can be difficult to capture. Here are some factors to consider when developing a mist collection system for this pesky machining byproduct.
At 0.7 micron in size, liquid smoke droplets are almost 30 times smaller than average mist droplets, and capturing them requires a very efficient and well-thought-out mist collecting system.
“Liquid smoke” is created by processes that heat and/or compresses fluids under high pressure, such as machining hard metals with straight-oil coolants. These processes produce a vapor that condenses back into a cloud consisting of liquid droplets measuring as small as 0.7 micron. These are smaller than droplets found in traditional machining mist, although both present health, safety and environmental risks if not properly captured.
In this article, Nick Welter, district manager for Donaldson Torit, provides three steps for developing an efficient, well-thought-out mist collecting system for liquid smoke.
4-way Bed Precision Lathe Features Automated Cycles
Long and thin workpieces can be machined without reclamping on this new machine from Weiler, according to the company.
Dielectric Oil Dramatically Reduces EDM Maintenance
Plagued by repeated small fires that interrupted its wire EDM throughput, this cutting tool manufacturer changed its dielectric oil and both eliminated fires and reduced its oil consumption.
3+3 Air Chuck Features Extended Stroke and Self-Centering
To keep up with the demands of the oil and gas industry, SMW Autoblok introduces BBFZA2G Air Chuck, featuring an extended stroke clamping range and three self-centering jaws.
