SmartCAM
Simulation Saves Money When Machining Expensive Parts
Jobs machining expensive materials mean Keselowski Advanced Manufacturing needs to be extremely cautious. The operations manager says Vericut not only prevents mistakes, it shortens cycle times.
A photo of an employee at KAM removing a part from a 3D printer
KAM specializes in 3D printed metal parts, both in the printing and the finish-machining stages. These parts are worth tens of thousands of dollars by the time they reach the machines, and thus require careful strategies for machining. Photo Credit: Keselowski Advanced Manufacturing
Since 2018, Keselowski Advanced Manufacturing (KAM) has become a preferred supplier to companies throughout the aerospace and defense, energy, space, automotive and performance motorsports industries.
Representing a new breed of vertically integrated hybrid manufacturing firms, KAM specializes in the design and production of 3D-printed metal parts that are then finish-machined on a fleet of high-end CNC machine tools. It's demanding, difficult work that is compounded by the fact that any mistake can undo weeks of laser bed fusion manufacturing and cost tens of thousands of dollars in material and machine time.
"Unlike machining from billet and bar stock, the parts we're cutting already have considerable value to them,” says James O’Toole, KAM’s operations manager. “Scrap at this point in the manufacturing process could cause serious problems for our customers, never mind the internal expense.”
Simulation provides a way to avoid this expense — but time spent simulating production needs to be recouped elsewhere for efficient cycle times, so KAM also needed software that could perform effective toolpath optimization. According to O’Toole, Vericut from CGTech struck the right balance for KAM.
“Not only does Vericut help us to ensure that the first part is a good part, but it helps us to reduce our setup times, eliminate broken tools and prevent crashes,” O’Toole says.
The Right Software for the Right Job
KAM’s shop floor is home to a variety of Mazak equipment, among them an HCN-5000 horizontal machining center; a Variaxis i-800 five-axis, twin-pallet vertical machining center; a Quick Turn 350MSY turn-mill center; and several Integrex i-300S seven-axis multitasking lathes. The additive side of KAM’s production area also boasts a large array of equipment, with nearly two dozen laser powder bed fusion (LBPF) printers from EOS, SLM Solutions and GE Concept Laser. Some have dual- or quad-laser capabilities, and all are capable of building parts from aluminum, Inconel 625 and 718, titanium Ti64, Haynes 282 superalloy and several other aerospace-grade metals.
Under O’Toole’s supervision, the two departments work very closely with one another and KAM’s design and engineering department. The process plan for any part starts by creating the 3D printing job or “build” in Materialise Magics software, simulating it in Netfabb Ultimate and then releasing it for 3D printing. After thermal processing, the printed job moves to the machining area. It’s here that KAM uses Vericut to simulate the NX-generated part program, checking for gouges, uncut material and collisions.
"We have a very strong programming team, but we're all human, and humans make occasional mistakes," O'Toole says. "While it doesn't happen very often, we've had multiple instances where Vericut has caught errors that would have scrapped a very expensive workpiece.”
A rendering in Vericut of a simulated collision
Collisions are disastrous for KAM, so Vericut’s focus on collision avoidance made it especially attractive for the shop. Photo Credit: Keselowski Advanced Manufacturing
Wayfinding Workholding
O’Toole noted that one of the more important considerations when machining 3D-printed parts is workholding. Some parts are machined still attached to the build plate, making workholding much easier, but others need to be cut away beforehand. In these instances, determining the best way to fixture what are often thin-walled parts containing complex geometries and freeform surfaces can be quite challenging.
On a traditional billet-made part, operators can determine any subsequent locating features during the first operation, O’Toole says. With additive, the parts don't have those datums defined, even though there are features that must align to them when complete. He compares this to castings and forging, which require finding the “part within the part.”
“You need to strategically look at how you are aligning and then probing the part to make sure that the features you’re machining end up in the right place,” O’Toole says. “We use Vericut here as well, to simulate our probing macros. Not only does it help us to ensure that the first part is a good part, but it helps us to reduce our setup times, eliminate broke tools and prevent crashes.”
HCL CAMWorks 2024
ProShop
Siemens Zel X
Surface finishing in Fusion
SmartCAM
SPONSORED
Automated CAM Programming – Is Your Software Really Delivering?
A look at the latest automation tools in Autodesk Fusion 360 software and how forward-thinking machine shops and manufacturing departments are using them to slash delivery times and win more business.
CAD/CAM
When to Use Custom Macros With a CAM System
Custom macros can offer benefits even when using a CAM system to prepare programs – but must be implemented with the right considerations.
SPONSORED
Finally, A Comprehensive Software Solution Designed for Small Job Shops
CAD/CAM
Reinvestment in automation has spurred KCS Advanced Machining Service’s growth from prototyping to low-and mid-volume parts. The key to its success? A young staff of talented programmers.
CAD/CAM
Aerospace Shop Adopts NC Optimization as a Means of Continuous Improvement
Steelville Manufacturing adopted CGTech’s Vericut NC verification software to safeguard its high-volume/high-mix work, but found unexpected benefits from its Force Optimization module.
CNC & Machine Controls
CGTech's OptiPath and Force Modules Prove Complementary
The OptiPath and Force modules of CGTech’s Vericut software have improved programming and cycle times at Ultra Machining Company.
Additive Manufacturing
Metal Additive Manufacturing: Multitasking’s Latest Trend
Why are an increasing number of machine tool builders adding additive manufacturing to their equipment’s already versatile machining capabilities? Because additive and subtractive are complementary.
HCL CAMWorks 2024
