High Speed Spindle Helps Mold Maker Stay Ahead
In the competitive arena of moldmaking, shops must produce molds quickly and within tolerance to remain profitable and attract new business. Technological advances in high speed spindles, sophisticated programming methods and high-performance cutting tools allow shops to save time and improve accuracy.
In the competitive arena of moldmaking, shops must produce molds quickly and within tolerance to remain profitable and attract new business. Technological advances in high speed spindles, sophisticated programming methods and high-performance cutting tools allow shops to save time and improve accuracy. However, molded parts are more complicated than ever before because designers are using the latest CAD programs to create parts that would have been unthinkable 5 years ago. So in the quest to improve efficiency, many mold makers are encountering difficulties.
"People say the computer is making things easier," says Randall Ohnemus, president of C&R Molds, Inc. (Ventura, California), "but computers are making things harder for us. Parts have more details these days, because designers can put in all these radii and blends. When parts were drawn by hand, they weren't as complicated, because they were hard to draw."
C&R Molds constantly looks for ways to improve its production. The company employs 40 people and runs three shifts per day to provide full service, from design to production. Backed by ten injection molding presses, the company can take new products from concept to reality—all under one roof. The 12,000-square-foot shop produces molds for a variety of products, from dental tools to water cooler components. Some of the materials the company works with include H13 steel, P20 pre-hardened tool steel and 7075 aluminum. Molds are roughed out on a Haas VF-0 and then finished on C&R's VF-2 with a new high speed spindle.
Since February 2002, C&R has used the vertical machining center equipped with a 30,000-rpm spindle from Haas Automation (Oxnard, California) to perform finish operations on molds. The company has seen a big difference between the new small cutters and what they had before, Mr. Ohnemus says. In addition to yielding better finishes, the spindle also reduces the company's cutting time and allows faster job completion. The same programs that ran on a 15K [15,000-rpm] spindle now run at double their previous speeds and feeds on the 30K spindle. Finish cuts are taken with step-overs of 0.002 inch and depths of 0.002 inch. In addition, the high spindle speed has allowed them to maintain proper chip loads and high surface feed rates.
Proper tooling is another issue the company must continually address in order to improve efficiency. Recent changes in part design, combined with increasing part complexity, have led the company to change its tool selection. It used to be able to cut things with tapered end mills. "But nothing is flat anymore," explains Mr. Ohnemus. "Everything is now blending radii into other surfaces, and that's why we've had to adapt and use ball end mills."
C&R uses ball end mills as small as 0.010-inch diameter to make the finish passes on cavities and mold surfaces. Improvements in cutting tools have helped the company to employ the capabilities of the 30K spindle, and the end mills are making the machine work. The new coatings allow high rpm, so the machine can get through an entire part, whereas before it would have burned up the tool.
Programming and software have made it possible to machine complicated molds. C&R uses the latest version of MasterCAM to program tool paths—allowing time on certain jobs to decrease from days to hours.
In the past, C&R relied on electrical discharge machining (EDM) for some of the more complex jobs, but now the speed and accuracy of the spindle allow it to machine cavities that were once the domain of EDMs. Since switching to the 30K spindle, the company has eliminated about half of its EDM work because it can machine areas of mold faster. "Previously, we would have burned the thread on this one mold," Mr. Ohnemus explains, "but we were able to machine it with the high speed spindle." Eliminating the need to create electrodes also saves time.
However, electrodes have not been eliminated completely; C&R still uses EDM for certain molds, but this does not mean that the 30K spindle sits idle. Rather, it is put to work machining electrodes, which has boosted electrode production considerably.
The change in vertical machining centers has also reduced the time spent hand finishing and polishing molds. Hand finishing can take days, but the company has reduced the time spent hand finishing by 80 percent with the new machine. By taking light passes at extremely high feed rates with small cutters, the part gets a smooth finish. With some of the small end mills, C&R was able to eliminate much of the hand finishing. Moreover, the CAD-defined geometry and accuracy are maintained when hand finishing is eliminated.
As new technology is making products better, it is also making the production process more complicated. However, the same technology is also helping C&R Molds and companies like it to create molds faster and more accurately than ever before.
What to Do When Five-Axis Machining Is Off the Table
For Fischer USA, 3+2 machining with a high-precision rotary table adds flexibility without the cost of a full five-axis machine.
Read MoreIn Moldmaking, Mantle Process Addresses Lead Time and Talent Pool
Read MoreBest Practices: Machining Difficult Materials
Read MoreAdditive/Subtractive Hybrid CNC Machine Tools Continue to Make Gains (Includes Video)
