Got Glue (And UV Light)?
Here’s an effective albeit atypical way to fixture parts such as thin-wall castings that are prone to flexing when conventional mechanical clamps are used.
Sometimes shops have to get pretty creative when trying to figure out how best to fixture a part for machining. Precision Grinding and Manufacturing, in Rochester, New York, leverages an atypical technology to fixture parts such as thin-wall castings that are prone to flexing when conventional mechanical clamps are used.
In short, this technology, available from Blue Photon Technology and Workholding Systems, uses adhesive to temporarily bond a workpiece to numerous cylindrical grippers installed in a fixture plate. Once the adhesive is cured via ultraviolet (UV) light, the workpiece is securely held at a known datum location in an undistorted, free-state condition. After machining, the adhesive bonds between the grippers and workpiece are easily broken and any excess adhesive is removed from the completed part via a quick, steam-cleaning wash.
Read this story to learn how PGM is using this technology to its advantage.
Fixturing Castings Made Simple Through Adhesive Workholding
Machining Vektek Hydraulic Swing Clamp Bodies Using Royal Products Collet Fixtures
A study in repeatable and flexible workholding by one OEM for another.
