During IMTS, Eriez introduced a portable inline fluid reclamation device it calls “SumpDoc.” This mobile unit provides complete coolant restoration and rejuvenation treatment of the metalworking fluids in the machine tool sump with minimal operator interface. Plus, there’s no need to shut down the machine to use it.
After locating the SumpDoc next to a machine’s sump and making the connections for water, electric and compressed air, the unit is ready to begin fluid rejuvenation. The operator first selects the Sump Vac Mode from the unit’s dashboard control. The sump vac portion of the portable unit is equipped with a long, two-inch-diameter hose and aluminum angled crevice tool for suctioning the bulk of the chips out of the sump. Solids are trapped in a 50-micron polyester bag and the coolant returns to the sump so the machine can continue to operate.
Next, the operator selects Filtration Mode from the control. The suction hose connected to the unit’s air-operated diaphragm pump is positioned in the machine tool sump while the discharge hose from high speed centrifuge and/or tramp oil coalescer is directed back to the machine tool sump. The coolant continuously re-circulates to the sump during the filtration mode to provide uninterrupted machine tool operation. During this step, the operator is free to conduct other activities until the filtration mode is complete.
After running in filtration mode for a predetermined amount of time, the operator checks the coolant concentration level with the onboard digital refractometer. The operator then selects Coolant Makeup Mode from the controls and chooses the proper coolant concentrate mix (lean, standard or rich). Once the sump tank reaches the desired concentration level, the process is complete.
At this point, the SumpDoc can be disconnected and moved to another machine. Pretty handy.
The 2023 STLE Tribology Frontiers Conference and Tribology & Lubrication for E-Mobility Conference will provide attendees with two opportunities to share and learn the latest tribology and lubrication engineering science.
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
