Gravotech
CNC Machining and Motorsports
Have a look at some of the new manufacturing equipment spotted in “Machinery Row” at the recent Performance Racing Industry Show.
Seeing as though I’m the magazine’s resident “car guy,” you’re probably not surprised that I attend the annual Performance Racing Industry Show whenever I can, as I did last week. This year marks the 32nd edition of the show, which draws attendees from all 50 states and 70 countries. Many of the exhibitors are manufacturers and suppliers of equipment to support the motorsports industry. (The 2019 event at the Indiana Convention Center in Indianapolis featured 1,100 exhibitors in 3,000 booths.) That said, the show’s “Machinery Row” features manufacturing equipment and software such as machine tools, tooling, workholding devices, CAD/CAM packages and so on.
That’s where I spent the majority of my time at the show. Read through the the photos and descriptions below to see some of what I saw there. Much of it has broader potential applications than just motorsports. In addition, this Twitter thread includes video and some additional automotive eye candy.
Full five-axis machining is often performed to shape and smooth cylinder head ports. This A590 machine from Centroid has a 180-degree articulating head and 40-hp/16,000-rpm spindle. Note the means by which the head is fixtured to a plate on the rotary indexer.
pri show
Here is an example of a combustion chamber’s contoured geometry and quality surface finish created via five-axis machining.
pri show
The sophistication of CNC machining technology on display at the PRI Show continues to increase. This L12 Swiss-type lathe from Marubeni Citizen-Cincom is an example. I believe it is the first Swiss-type I’ve seen displayed at the show.
pri show
Hurco highlighted the 3D solid model import feature in its Max5 CNC, which is based on DXF technology. There is no need to enter feature dimensions, and transform planes are created automatically for five-sided conversational programming.
pri show
Sunnen has teamed with Applied Nano Surfaces to offer triboconditioning, a mechanical-chemical process that applies a compound that becomes integrated into metal at a nano level. (It is not a coating.) One application is engine block cylinder sleeves. When combined with honing, it can eliminate the "break-in" process for new engines.
pri show
Having a compact footprint and short travels, the Haas UMC 500 five-axis machine is well-suited for five-axis positioning or full contouring of small, complex components.
heidenhain at pri
Machine shops can get better performance from manual knee mills with a CNC retrofit kit like Heidenhain’s Acu-Rite brand offers. The kit includes new ballscrews, drives, control, and scales on X, Y and Z axes. The company says even big OEMs are retrofitting theirs, so it’s not just for small shops.
trak machine tools at PRI
Available in the United States from Southwestern Industries Inc., Trak Machine Tools’ Prototrak 2OP is a compact VMC that can be used as a second-op machine or a standalone unit. The latest design features a 10,000-rpm spindle.
chick at pri
Chick’s OneLok vise jaw system enables fast jaw changeovers. Once a jaw is inserted, it is secured after a few twists of a T-handle wrench.
omax at pri
This Omax ProtoMax is a compact waterjet machine that can cut a range of materials up to 1-inch thick. It is well-suited for small job shops, engineering classrooms, makerspaces and hobbiest use.
mass finishing at PRI
Mass Finishing Inc. (MFI) offers centrifugal barrel finishers used to deburr and polish parts. MFI says a part that might take four hours to finish in a vibratory tumbler can be completed in 20 minutes using its system. The concept is similar to a Ferris wheel, in which parts and media are installed in barrels that rotate as the turret rotates. This motion causes parts and media to contact each other, smoothing part finish.
Gravotech
High Accuracy Linear Encoders
Gardner Business Intelligence
SPONSORED
SolidCAM Wants to Help Machine Shops Get into Additive Manufacturing
SolidCAM's partnership with Desktop Metal is aimed at making additive manufacturing more accessible to job shops and other manufacturers.
Automotive
4 Tips for Staying Profitable in the Face of Change
Automation
Ford Partners With Rockwell Automation to Advance EV Program
The companies will jointly collaborate on assembly tooling designs and architectures that will increase speed to market.
Automation
New Laser Technology in Non-contact Optical Dimensional Metrology
LADAR technology from API sets a new standard in non-contact optical dimensional metrology for manufacturing industries.
CNC & Machine Controls
Shop Applies App to Adopt CNC Technology Faster
A custom machine-operating and automatic program-generating app has helped racing parts maker Moser Engineering quickly reap the benefits of CNC machining even though nobody there had any prior experience with it.
Inspection and Measurement
Racing to Create Custom Pistons
Laser scanning technology enables this automotive aftermarket company to design and machine custom sets of pistons in short order.
Gravotech
