A Tool Turret Tailored For The Task (Of Multitasking)
When Hardinge Inc. (Elmira, New York) designed its new "flagship" line of multitasking CNC turning centers, it paid particular attention to the turret tooling top plate.
When Hardinge Inc. (Elmira, New York) designed its new “flagship” line of multitasking CNC turning centers, it paid particular attention to the turret tooling top plate. On this type of machine, the top plate plays such a critical role that it can be either a weak link or major strong point. Well aware of this, the company chose a turret style that features a self-aligning top-plate configuration. This turret top plate system is integrated on the RS-Series of multitasking turning centers with a “collet-ready” spindle and is available on the SR-Series multitasking turning centers for universal chuck and bar work.
What made the designers so conscious of the top plate’s importance was the experience of the firm that developed this turret design. That firm, Eppinger GmbH, is a German tooling manufacturer originally founded as a maker of static toolholders for lathes. During the last 20 years, the company shifted its focus to live tooling for CNC turning centers. Along the way, Eppinger acquired several Super-Precision Quest turning centers from Hardinge to do hard turning. The turning centers were equipped with VDI tooling top plates, which are commonly found on this type of machine. According to Uwe Eppinger, company president, this application was quite successful.
However, the company discovered that, as effective and flexible as VDI-style tooling is, something more was needed to take machining of hardened materials to the next level of precision and productivity. The VDI system, which is based on a standard that defines a tool shank and matching machined pocket, did not lend itself to extreme hard-milling and hard-turning applications with live tooling in a multitasking environment. Greater rigidity and more precise alignment were called for.
Drawing on its firsthand understanding of these machining challenges, the company developed a new concept for tool-turret design. Rather than relying on the machined tool pockets to position the toolholder body, the design uses a zero-clearance key system. Each of the turret’s 12 stations has a key used to move it along Y axis for a virtually perfect alignment with the centerline of the main spindle. In turn, each toolholder body is positioned with a keyway that is pulled against the key on the top plate. The key makes contact with only one side of the keyway so that key and keyway clearance is not a factor in positioning accuracy. A pushbutton on the top plate activates the gripper retention knob for “hands-free” tool installation. The four bolts that attach the toolholder body to the backplate’s ground surface provide rigidity while tightly locking in the precise positioning, the company says
The toolholder bodies are designed to interface with the company’s modular tooling system. Called Preci-Flex (for precision flexibility), this system features interchangeable components. In each toolholder body, the spindle-collet seats have a ground spindle nose with four threads. The spindle of the toolholder body accepts either a traditional ER collet or an adapter with a cone-face contact that is the same shape as a collet. The adapter is bolted down under the spindle and sits in the ER seat, so it has contact with the ground spindle nose. According to the company, this results in high repeatability and a very rigid connection between the adapter and the spindle.
With the adapter, the cutting tool can be clamped and preset outside the machine while the toolholder body remains attached to the top plate. Cutting tools and adapter assemblies can be exchanged quickly and still achieve highly repeatable positioning with low runout. Precise alignment of the toolholder bodies combined with the low runout of the adapters prolongs tool life because cutting conditions are highly consistent whether turning or milling hardened materials, the company says. In addition, each station can be equipped with a driven tool for cross or end milling/drilling operations.
As a Hardinge customer, Eppinger was eager to share its new turret technology with the machine tool builder. Because of the system’s apparent advantages, Hardinge was equally interested in integrating this turret design on its new CNC turning centers. The Eppinger Self Alignment (ESA) turret is supplied on an exclusive basis as a standard feature for the RS-Series and as an option on the SR-Series.
The two companies concur that the ESA turret complements the capabilities of the new Hardinge multitasking turning centers for which it was designed. The RS-Series machines are intended for hard milling and hard turning complex workpieces in one setup. They feature a collet-ready ground spindle and linear guideways. The series comprises two ranges: three Super-Precision models with overall axis repeatability of 0.00003 inch/0.76 micron, and three general precision models with overall axis repeatability of 0.00005 inch/1.27 micron. Available in two sizes, the SR-Series machines are positioned as heavy-duty “chuck-and-bar” turning centers. The design includes roller guideways and oversized ballscrews. Featuring a 150- or 200-mm three-jaw chuck for applications requiring high horsepower (as much as 30 hp) and high torque (as much as 270 foot-pounds), the models mark the company’s entry into the market for chucking machines in this size range.
Read MoreInverting Turning and Five-Axis Milling at Famar
