End Mill Comparisons in CFRP, Part 3 - Conventional PCD Tool
Video shows the performance of coated carbide, diamond-coated, PCD and veined PCD tools in carbon fiber reinforced plastic. Part three in a four-part series.
Smith MegaDiamond Inc. and Star Cutter Company compared the performance of various end mills in carbon fiber reinforced plastic (CFRP). The tools tested included a coated carbide end mill, a diamond-coated end mill, a conventional PCD end mill with straight flutes, and a “veined” PCD end mill featuring a vein of PCD within a helical slot in a carbide tool body.
The table below summarizes the test parameters. Shown here is the video of a straight-flute segmented PCD tool. Jeff Michael, engineering manager for Star Cutter, comments, “Notice the sound includes pounding. This is the effect of the cutter loading and unloading because of the straight flutes. Also, there are uncut fibers because of the lack of shearing geometry.”
To see the next video in this testing, click here.
Tool Type |
Ø .500 in. |
Solid Carbide |
CVD Diamond |
PCD |
Veined PCD |
Flute angle |
30° helical |
10° helical |
7° skew |
30° helical |
Spindle speed (rpm) |
3,000 |
4,600 |
12,000 |
18,000 |
Chip load (in./tooth) |
0.0035 |
0.0035 |
0.001 |
0.0065 |
Machine advance (in./min.) |
42 |
64 |
36 |
470 |
Radial depth (in.) |
.050 |
.050 |
.050 |
.050 |
Cutting speeds and feed rates were recommended parameters from each tool’s manufacturer.
Editor’s note: To read the next part in the series, click here.
Sandvik Coromant Launches New Range of Solid End Mills
The CoroMill Dura range is designed for roughing and finishing with different engagements in all applications and materials.
10 Tips for Titanium
