World’s Smallest Boring Head?
With a diameter range of 0.016” to 0.276”, this boring head is well-suited for a variety of micromachining applications.
Big Kaiser says it has produced the industry’s smallest finish boring head. Its EWN 04-7 series is designed for use on micro-milling machines with high speed spindles such as HSK-E25, E32 and E40 models.
This boring head has a diameter range of 0.016" to 0.276". It features a high-precision adjustment accuracy of 0.0005"/diameter or 0.0001"/diameter with the use of a Vernier scale. The head is available with the Kaiser KA1 modular connection or with a 10-mm-diameter straight shank, and can accept boring bars with 4-mm-diameter shanks. Maximum through-tool coolant pressure is 300 psi. High rigidity and secure clamping of the boring bar makes it well-suited for many micromachining applications including those that require small-diameter boring deep inside cavities.
Learn about other micro-milling solutions in our Micromachining Zone.
3 Tips to Accelerate Production on Swiss Lathes with Micro Tools
Low RPM lathes can cause tool breakage and prevent you from achieving proper SFM, but live tooling can provide an economical solution for these problems that can accelerate production.
Where Micro-Laser Machining Is the Focus
A company that was once a consulting firm has become a successful micro-laser machine shop producing complex parts and features that most traditional CNC shops cannot machine.
