Next Generation Cleaning Technology Handles More Complex Parts
New parts cleaning processes are developing that can handle more complex parts in more environmentally friendly ways.
Mafac’s vector kinematics cleaning system is designed with the notion that the more motion taking place while cleaning, the better the cleaning process.
Like all precision machining technology, parts cleaning technology is always evolving. The latest cleaning trends point toward environmentally friendly ways to clean effectively, involving the replacement of harmful chemical solvents within a cleaning process or switching to a mostly aqueous method. Other shifts in the industry involve updated processes that clean and dry complex parts better than ever before. Dry cleaning technologies and optimized alternative cleaning methods are other trends being experienced, especially in Germany where standards are more stringent for technical cleanliness.
Because 3D-printed parts are being produced more regularly, the focus on cleaning and drying these sophisticated parts better has become a trend.
Cleaning technology is being developed that is more effective for cleaning and drying complex metal parts that contain small recesses or holes. Because 3D-printed parts are being produced more regularly, the focus on cleaning and drying these sophisticated parts better has become a trend.
This LPW PowerJet fully automated, two-chamber system is for cleaning medical devices using ultrasonics and CNp.
Cleaning processes using cyclic nucleation (CNp) is one example of a technology that intricate parts are benefiting from. CNp is a vacuum flood cleaning method in which parts in a filled and sealed vacuum chamber are brought into contact with the cleaning fluid. The resultant gas bubbles are formed on all reactive surfaces, even in complex part structures such as capillaries and holes. If there is a sudden removal of the vacuum, these bubbles fall into each other and generate a pressure wave with a mechanical effect on the entire surface of the components, even in concealed areas. This method can be used alone or in addition to conventional cleaning methods.
An upgraded vector kinematics process is another cleaning method used for spray cleaning metal parts, especially those with blind holes and recesses, that has been developed recently. German aqueous parts cleaning manufacturer Mafac’s latest vector kinematics process includes even more movement for cleaning and drying components.
In contrast to the process using a conventional nozzle system, the workpieces being cleaned with the vector kinematics method are not hit at a specific angle. Instead, the nozzle tube performs a rocking, rotational movement 35 degrees to either side, while the basket receptacle system rotates synchronously at an adapted speed. This movement, combined with temperature and cleaning additives provides a fast, energy-saving cleaning process.
For electronic and already assembled parts, there is a trend toward dry cleaning technologies. When it comes to fulfilling high particulate, organic and/or inorganic or biological cleanliness requirements, there are new cleaning and drying processes for wet chemical cleaning, as well as new and optimized alternative cleaning solutions such as plasma, laser and CO2 snow-jet cleaning.
Even though the best cleaning technologies for an application might be implemented, it can still be necessary to ensure the highest cleanliness standards are reached after parts are cleaned using microscopy inspection. And cleaning inspection never goes out of style.
There are many cleaning equipment solutions that will accomplish cleaning goals; therefore, it can be overwhelming to choose the best one for an application. But with the help of cleaning OEMs and/or professionals who specialize in solvent or cleaning agents, a manufacturer can discover the most ideal cleaning process.
