Small Hole EDM and Achieving EDM Goals
Flexible, Multi-Spindle, Non-Rotating Bar Machines
Buffoli’s Trans-Bar Digital CNC flex machines are rotary transfer machines with both single- and double-bar capacity.
Buffoli’s Trans-Bar Digital CNC flex machines are rotary transfer machines with both single- and double-bar capacity. The machines are designed for high-efficiency machining with fast change-over and can machine non-rotating bar/tube of virtually any profile or material. The bar machines feature double-wall frames, a 3,000-kg (6,500-lbs) capacity bar feeder, an integrated cut-off system and a multi-processing digital CNC.
