Doubling Down on Setup Reduction
Angle heads still find plenty of use for reducing setups, even in shops using sophisticated multi-axis machine tools.
Despite a long history of helping manufacturers reduce setups, the angle head might seem like little more than a relic in an era characterized by increasingly sophisticated multi-axis machine tools. According to Big Kaiser Precision Tooling, however, that’s not the case at all. In fact, manufacturers are finding that this tried-and-true can help double-down on the setup-reducing capabilities of four- and five-axis machines, particularly in the aerospace and energy industries. That said, they do come with inherent limitations that any potential user should keep in mind. Learn more here.
Rego-Fix Toolholding System Reduces Coolant Consumption
Haimer USA Models a Streamlined Toolroom
Haimer USA is celebrating its 20th anniversary with a live demonstration of its digital toolroom. Find out more past the aluminum panther.
