Cylindrical Grinder Takes on Complex ID Operations
One of the centerpieces of United Grinding’s booth at IMTS is a grinding machine designed for ID grinding of hard materials.
The United Grinding North America booth at IMTS is showcasing the Studer S131r cylindrical ID-radius grinding machine. According to the company, the machine is designed for difficult ID grinding operations where maximum precision is paramount.
The Studer S131r grinding machine is one of the centerpieces of United Grinding’s booth at IMTS. The machine is designed to handle ID grinding for difficult materials.
Photo Credit: United Grinding
The Studer S131r can tackle both general grinding applications and the production of complex workpieces made from very hard materials. It is also suited for hydraulic components such as axial pump pistons, guide plates and housings made from hardened steel, cast iron and copper. The machine also handles single-clamping production of complex workpieces with tapers between 20°
and 90°.
The machine's fully automatic, completely sealed, simultaneously swiveling direct-drive B-axis offers superior thermal stability, mechanical rigidity and interpolation from -60° to +91°. Additionally, the workhead C-axis enables form and thread grinding. High-precision axis drives with linear motors add speed and accuracy, and a -50° to +280° swiveling spindle turret with up to four grinding spindles enhances grinding flexibility. Temperature-stabilized components maintain precision while a Granitan S103 mineral-cast machine bed provides vibration damping.
The S131r can machine external diameters up to 160 mm (6.3 inches) with an external grinding wheel 250 mm (9.84 inches) in diameter. The S131r accommodates parts up to 300 mm (11.81 inches) long and as heavy as 100 kg (220 pounds), including clamping devices.
StuderSIM software enables operators to machine complex parts, often in a single clamping. StuderSIM derives workpiece geometry from a drawing, completely defining and generating all the data required for grinding cycles. Furthermore, operators can simulate grinding to easily check and visualize the processes on a PC or on the machine itself.
Check out the S131r at booth 236802 in the North Building.
Medical Manufacturing Must-sees
The realm of medical manufacturing includes precision cleaning, exacting tolerances, additive manufacturing, ins and outs of FDA clearance and more. Anyone in the industry can learn more and keep up to date with latest in medical manufacturing at IMTS.
Beards of IMTS - Amazing Feats of Beard Engineering
Manufacturing has a multi-talented bunch of people, but who knew so many were adept in the facial hair industry? Check out the best of the beards at IMTS!
How is an EV Battery Made?
Everyone talks about batteries, but how are they produced? Here’s the long and short (circuit) of it.
