Behind Closed Doors
Lang Technovation’s Clean-Tec fan clears away chips and coolant inside enclosed machining centers.
Available from Big Kaiser, Lang Technovation’s Clean-Tec fan is an alternative to compressed air guns for removing debris from workpieces within enclosed machining centers. Unlike handheld air guns, the fan runs with the machine doors closed, protecting the operator from sprays of coolant or metal chips. And, because the fan operation is included in production programs, it’s a viable option for unattended or lights-out production.
The fan is constructed of a fiberglass compound with a steel center core and can be fitted into 20-mm or 3/4" diameter commercial shanks. Its fiberglass wings open when the spindle is turned on and collapse when it stops for easier storage, as shown in the video above.
Jorgensen Partners With Will-Fill on Coolant Management System
Will-Fill’s automatic coolant monitoring and managing systems are now featured on Jorgensen’s filtration systems.
Fortech Synthetic Coolant Enables Bio-Stable Metal Removal
Fortech’s TechKool FT4000 synthetic coolant is formulated to reject tramp oil that can cause smoking or misting and premature spoilage of coolant.
High-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
