An Indexable Insert
The solid end mill is a machine shop staple. Its positive cutting edge removes metal by slicing through the material, rather than by scraping.
The solid end mill is a machine shop staple. Its positive cutting edge removes metal by slicing through the material, rather than by scraping. This reduces cutting forces, power required to make the cut and the possibility of inducing vibrations. These reasons are why solid end mills remain popular for low-horsepower machine tools with limited structural mass to damp vibrations.
Solid end mills do require periodic regrinding, and there is a limit to how many times this can be done to a tool. As an alternative, manufacturers have designed indexable insert end mills with positive radial and axial rake angles to emulate the solid end mill's cutting action, while allowing insert indexing and changeout. Until recently, though, a key feature of the solid end mill—eccentric relief, or "margin"—has not been replicated in an indexable insert cutter.
Big Daishowa Seiki has developed what is says is the first indexable insert end mill to combine positive/positive rake angles with eccentric relief, a la the solid end mill. We had the opportunity to preview the company's Fullcut end mill while visiting its manufacturing facilities and technical center located on Awaji Island, just off the coast of Osaka, Japan. Now available in the United States from Big Kaiser, Big Daishowa's partner located in Elk Grove Village, Illinois, this end mill design combines smooth, low-force cutting with insert changeability, while eliminating regrinding.
Eccentric relief is the positively arched (convex) area behind the cutting edge, as shown on the right-hand image in Figure 1. The profile brings the insert's sharp cutting edge nearly even with the body diameter to provide greater edge support. Unlike a concave, negative profile with a high clearance angle that tends to cantilever the insert from the body, eccentric relief more effectively directs the forces from the cutting edge into the tool's body. This geometry is less likely to cause insert chipping, which is prone to occur at the start of a cut (when cutting forces are highest) or during interrupted cuts.
Lower cutting forces can permit higher speeds and feeds, without increasing the risk of chipping. The Fullcut's insert geometry allows for shoulder, slotting and facing operations, but it can't be used for Z-axis feeding operations, such as plunge cutting or boring.
The end mills range in diameter from 0.5 inch to 2.0 inch, with inserts tailored to each diameter to maintain proper geometry. Each insert can be indexed once. The end mills are available in straight shank and integral body designs (V-taper, HSK and Capto) for high rigidity.
3 Examples of Machines that Combine Manufacturing Methods
Certain “hybrid” machines combine some form of additive manufacturing with CNC subtractive manufacturing. Columnist Mike Lynch, President of CNC Concepts Inc., explores three types of these machines here.
