Alcohol-Based Coolant Offers Environmentally Friendly Machining
This micro-volume coolant delivery system uses ethanol as the cooling medium for non-ferrous workpieces. The ethanol evaporates after it cools the cutting tool, so no residue is left behind on machined workpieces.
Ethanol may soon play a bigger role not only in the way future vehicles are powered, but also how micro tools are cooled during high speed machining (HSM) operations. Datron Dynamics (Milford, New Hampshire) has developed a micro-volume coolant delivery system for its high speed VMCs that uses ethanol as the cooling medium. The ethanol evaporates after it cools the cutting tool, so no residue is left behind on the machined workpiece. This alternate coolant technique eliminates the recycling and disposal issues inherent to petroleum-based coolants, and it makes secondary workpiece degreasing unnecessary. Ethanol’s low viscosity allows it to reach the tool tip for effective cooling and lubrication at high spindle rpms, which may not be possible using emulsion-based coolants.
Ethanol is a naturally occurring form of alcohol with a low evaporation temperature. Though flammable, it is safe for use with workpiece materials that will not spark or develop an unusually high amount of heat during the machining process. Suitable materials include non-ferrous metals such as aluminum, copper, magnesium and brass, as well as a variety of plastics (excluding some polycarbonates whose crystalline matrix may be damaged by the ethanol). It is obviously not appropriate for machining ferrous materials, because the sparks generated as a carbide tool cuts such material could ignite the ethanol. In addition, ferrous materials should not be used for workpiece fixturing, in case a cutting tool inadvertently contacts the fixture as a result of a programming or operator error. The fumes that are generated as the ethanol evaporates are removed via a fan located within the machine enclosure. Optional fire suppression equipment is available.
An effective coolant delivery system is important to reduce cutting temperatures during HSM operations. It is also necessary to provide proper lubricity to allow a tool to move swiftly across the surface of a workpiece, notes Dr. Walter Schnecker, Datron Dynamics’ president. “Micro tools require a lubricating agent with a lower viscosity than water to ensure that the coolant reaches the cutting edge of the tool at the high spindle speeds,” Dr. Schnecker explains. “Ethanol is thinner than water and runs quickly to a tool’s cutting edge. Emulsion-based coolants, which typically have a higher viscosity than water, are therefore not as effective in lubricating micro tools during HSM operations.”
The coolant delivery system consists of an ethanol reservoir and two delivery nozzles. The ethanol is sprayed on the tool and the surrounding workpiece surface in a fine mist—micro tooling does not need a significant volume of coolant. The maximum output of the system is 25 mL/min., which translates to a consumption rate of 0.4 gallons of ethanol per hour. Dr. Schnecker estimates that most users typically consume approximately 1 gallon of ethanol per machine per day. “Recycling an oil-based coolant can cost as much as $12,000 per machine per year; recycling emulsion-based coolant can range from $2,000 to $4,000 per machine per year,” he notes. “The annual cost for the ethanol is less than those costs.”
Datron Dynamics also offers a micro volume, vegetable oil-based coolant system for machining ferrous materials. The machine’s controller allows users to switch between ethanol and vegetable oil for machines that will process both non-ferrous and ferrous workpieces.
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
Read MoreIMTS 2022 Review: Attention to Automation Extends Beyond the Robot and the Machine
Read MoreFortech Synthetic Coolant Enables Bio-Stable Metal Removal
Fortech’s TechKool FT4000 synthetic coolant is formulated to reject tramp oil that can cause smoking or misting and premature spoilage of coolant.
Read MoreRenewable Lubricants Reduce Cleanup Costs
Bio-Air Tool Lubricants perform in many applications, offer better natural lubricity than petroleum-based oils and are safer for employees and the environment.
