Marposs
Rethink Quality Control to Increase Productivity, Decrease Scrap
Inspection equipment
Photo Credit: Getty Images
Over many years in the industry, I have noticed a few things that I believe need to change in machine shops. This column describes one that has been bothering me for a long time: quality control. I know this may ruffle a few feathers, but how we do quality control needs to change.
The standard practice that I see in most machine shops is that when a machine is set up, the first parts are sent to quality control for inspection and verification. The machine usually sits idle until the green light of approval is given by the quality control department, which can take a while depending on how busy the department is. Then, once the green light is given, the machinists boot up the machines and start making parts. Intermittently throughout the production process, sample parts are sent to quality control to verify that they are still within specifications.
Despite the fact that machine operators are measuring parts manually, there are usually features they will have difficulty measuring, as the equipment necessary to make these intricate measurements can only be found in the quality control room. If quality control personnel detect a problem, then the manufacturing equipment is stopped, the process is corrected and the suspected nonconforming parts need to be quarantined and sorted — parts that are nonconforming are usually scrapped.
I have seen this process play out in many shops, and over the years it has begun to bother me because it seems so wasteful in terms of time and productivity. Verifying parts is essential to documenting quality, but there needs to be a better practice that will increase productivity while decreasing scrap.
The first practice deals with in-process measuring at the machine level — the CNC part-making machine should be doing the measuring. Machine tool manufacturers should be integrating a measuring system at the design level into the machine tool. I know there are after-market products that can be integrated, but they are an add on. Add ons usually have their own issues, including software compatibility and placement, which sometimes make these systems very difficult to work with.
When a machine tool manufacturer builds the parts measuring system into the machine, the placement of probes and software is more integrated. This makes it easier to do in-process inspection on an active basis since the machine tool was designed to do this from the start. It will also enable for integrated recording of measurements since it can be built in. Integrated recording is key, as it enables machine shops to have automatic documentation without needing machine operators to do it. It will also allow the machine to adjust itself to keep parts in tolerance, which would decrease scrap.
Following this practice is not going to eliminate all inspections, but it would seriously increase productivity and quality.
The other practice is to move the quality control department closer to the manufacturing equipment. There are now shopfloor CNC measuring machines that are accurate and compact. They can be brought closer to the machines so that setup people and operators can measure their parts quicker and in-process without having to constantly walk over to the quality control room. If the quality control room is at the other end of the building, then the journey is long and wasteful. Having the quality control room nearer to the machines would get production up and going faster by eliminating the time spent going between the two.
I believe that the quality control department is there to verify that parts are made to the drawing — it is there as a resource for the shop. That being said, quality control must start at the machine and end on the shop floor. Yes, there will always be a department where temperature-controlled measurements of hard-to-measure features will have to made, but the primary quality control must be at the shopfloor level.
In this competitive world, we need to make parts faster and with higher quality. This is why we need to make changes to the quality control department. Start with machine tools that have in-process integrated measurement capabilities that produce documentation with high-quality inspection machines. To increase productivity, these machines need to be readily accessible to shopfloor personnel. This is how we can move manufacturing and quality control to the next level.
Marposs
WENZEL
The Automated Shop Conference
Gardner Business Intelligence
How Transparency Can Help Machine Shops Become More Efficient
Here are three areas that a machine shop owner can use to both share information and gather new information that would help them become more efficient and effective.
Close Collaboration With Customers Brings Job Shop Success
Contract machining operations win when they collaborate closely and openly with customers.
Overcoming Barriers to Machine Shop Automation
Industrial automation using robots has improved productivity for operations large and small — so why do some manufacturers shy away from it?
Sharing the Manufacturing Narrative With Policymakers
Conversations with policymakers represent a chance to communicate our challenges, showcase our passion and impact them with our pride in American manufacturing.
Basics
Vertical Machining Centers
WENZEL
