Campro USA
Seeing, Fulfilling Production Machine Shop Needs
What might you have noticed in someone else’s machine shop from which you could benefit from in yours? You likely will see it or something similar at IMTS.
swiss-type cnc lathes
Machine shops producing parts in high volumes face challenges that low-volume operations might not encounter. Source: Modern Machine Shop
I’ve spent the past two decades visiting and writing about machine shops for Gardner Business Media, currently as editor-in-chief of the Production Machining brand. During my shop visits, I try to be the eyes and ears of shop owners and managers who often don’t get a chance to leave their shops to visit other facilities. I often wonder what they would look at or inquire about if they were on-site with me. And I’ve asked shops that question. Here are some answers I’ve gotten … potential needs they have that could be met with technology on display at IMTS.
Workholding. This is by far the top answer. Is the shop using traditional workholding, fixturing, chucks and more that might take a good bit of time to change out? Or, is it using devices that offer quick-changeover capabilities to speed setups for new jobs? Batch sizes — even for high-volume production shops — are becoming smaller, so quick-change workholding can minimize downtime for what can be very expensive capital equipment, especially in our precision-turned parts industry.
Work in process (WIP). How much partially completed WIP is queued up near machines waiting for those machines to become available to perform secondary operations? WIP is a form of waste. Shops using multitasking machining equip­ment are much less likely to have WIP throughout their shop because they have machines that can oftentimes complete parts in one setup. This could be as simple as CNC lathes with live tooling.
Part handling/collection after machining. In a high-volume production machining environment using equipment that is commonly bar-fed, completed parts can be produced in short order. How are those parts collected so they don’t get damaged (or lost in the case for very small components) and is the means for part collection a bottleneck in a desired unattended machining process?
Shop management software. How is the shop tracking work as it flows through its facility from raw material to completed parts ready for customer delivery? For any given job, how quickly can the shop identify where that job is relative to its completion? Enterprise resource planning (ERP) software is becoming more prevalent in shops to offer immediate visibility in that regard as well as improved scheduling and other advantages. The days of using spreadsheets are soon coming to an end.
Tool management. Is there a central tool crib to manage and distribute tools to machine operators and setup personnel? Or, perhaps even better, is the shop using a vending system to track tool consumption and trigger tool purchases when inventory becomes depleted? There’s nothing much worse than thinking you have a tool on hand for a new job only to find out you don’t. And then you have to pay for expedited shipping to get that tool to your shop ASAP.
Machine monitoring. Is the shop relying on gut feelings as it makes decisions as to how shopfloor processes should be adjusted or is it using data such as that pulled from machine tools to make more informed decisions? Even simply knowing and tracking when a machine’s spindle is cutting and when it isn’t in a given shift can be very helpful.
Parts cleaning. Specifications for machined parts cleanliness continue to become more stringent. What process/processes is the shop using to meet those specifications? Many cleaning options are available, including those that eliminate the need for harmful chemical solvents, replacing with a mostly aqueous method. Automated cleaning processes can be very helpful in high-volume production environments, too.
SW North America, CNC Machines and Automation
Campro USA
JTEKT
IMTS+
Tooling
IMTS 2024: Trends & Takeaways From the Modern Machine Shop Editorial Team
The Modern Machine Shop editorial team highlights their takeaways from IMTS 2024 in a video recap.
Sponsored
Increasing Productivity with Digitalization and AI
Job shops are implementing automation and digitalization into workflows to eliminate set up time and increase repeatability in production.
Sponsored
The Future of High Feed Milling in Modern Manufacturing
Achieve higher metal removal rates and enhanced predictability with ISCAR’s advanced high-feed milling tools — optimized for today’s competitive global market.
Campro USA
