HCL CAMWorks
Machine tool with chip bin
Wolfram Manufacturing’s use of machine monitoring data from its own program, OnTakt, is evident from the equipment on its floor. The data showed chip management was causing a bottleneck, so the shop now has more chip conveyors than machine tools. Photos provided by Wolfram Manufacturing.
Wolfram Manufacturing started in 2011 as a machine shop in Austin, Texas. By 2024, the company has added “integrator” and “software developer” to its portfolio — it implements Caron Engineering products at manufacturers in the South and Southwest regions of the United States and now offers its own production management and machine monitoring software, called OnTakt.
All three business segments are interconnected, supporting each other on Wolfram’s quest for closed-loop manufacturing. “It’s like grabbing hold of a rocket,” says Nathan Byman, president of Wolfram Manufacturing. “We get better, and our products and services get better.”
The company recently held an open house to celebrate its move into a larger facility that will benefit all three of its divisions, with space for more machines, more staff and an area to showcase the software products it sells, integrates and supports. The event included guided tours of the shop, along with exhibitors and presentations from partners on topics including tooling and automation.
Machine tools on shop floor
Wolfram has been so successful with using Caron Engineering’s products in its own shop that it became an integrator and production technology center for Caron, expanding its business beyond machining.
“More Than Keeping Score”
Automation has proved to be critical to Wolfram’s success, particularly Caron Engineering’s products. It has TMAC, Caron’s adaptive tool monitoring program, on all of its machine tools, and has built several custom applications using MiConnect, including one that notifies operators when chip bins are full, and another that integrates RFID chips on the tooling for all machines.
The last application is part of Wolfram’s plan to automate tool loading and unloading with robots, along with an Omega tool presetter that can read RFID chips. The shop’s extensive use of these programs led to it becoming an integrator for Caron Engineering in 2015. Wolfram became a Production Technology Center for Caron Engineering in 2022, showcasing its use of the products to Caron Engineering customers in the region.
Machine monitoring is also a key component in Wolfram’s operation. The company began offering its OnTakt software product for machine monitoring and production management in 2022. Later that year, it acquired XMC to complement OnTakt with more communication and analytic capabilities.
Man demonstrating tool presetter
Wolfram’s three business units are all interconnected, ultimately helping the company achieve its goal of closed-loop manufacturing. This Omega tool presetter will play a role in the company’s quest for automating tooling loading and unloading with robots.
In regards to its own use of machine tool data, Byman says, “Machine monitoring is more than keeping score.” The team has used many insights from this data to improve operations. For example, Byman pointed out that the shop floor has more chip conveyors than machines. This is because Wolfram determined, based on its machine monitoring data, that its chip conveyors were causing downtime and calculated that if it added more, they’d pay for themselves quickly.
HCL CAMWorks
JTEKT
RazorStar
Machine Monitoring Boosts Aerospace Manufacturer's Utilization
Shop Quotes Smarter, Works Harder with Machine Monitoring
Temco first installed MT-LINKi to optimize quoting. Now, the software helps the shop optimize its machines — and machine purchases.
Sponsored
Swiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
5 Stages of a Closed-Loop CNC Machining Cell
Controlling variability in a closed-loop manufacturing process requires inspection data collected before, during and immediately after machining — and a means to act on that data in real time. Here’s one system that accomplishes this.
Caron Engineering Systems Integrator Expands Territory to West Coast
Wolfram Manufacturing, an integrator of Caron Engineering Systems, acquires new distribution areas.
Automation
Caron Engineering, Wolfram to Open Production Tech Center
Production Technology Center to open at Wolfram’s Austin, Texas location that will showcase Caron lights-out machining solutions.
Turn/Mill
Manufacturing Association Aids Shop’s Pivot to Ventilator Parts
After reaching out to the Austin Regional Manufacturers Association, a shop that typically serves oil and gas and heavy industry was able to quickly fill an order for ventilator parts.
HCL CAMWorks
