Star CNC
Video: Trochoidal Milling
This approach to rough milling replaces straight lines with “curlicue” moves of constant radius.
Loading the player ...
Photo courtesy Delcam. Video shows trochoidal milling in 52 Rc D-2 steel using a six-flute end mill. Video courtesy Niagara Cutter
This is an approach to rough milling in which straight lines are replaced by “curlicue” circular moves of constant radius. Potential benefits include:
  • Faster metal removal. Making the constant circular curve the only direction change allows a high feed rate to be consistently maintained.
  • Longer tool life. The cutting edge is in contact with the material through only about 5% of the cutter’s revolution vs. up to 50% for more conventional cutting. Cooling of the tool is improved.
Okuma
Marubeni Citizen CNC
Star CNC
MMS Top Shops
