QualiChem Metalworking Fluids
Air in Your Favor
Blasting coolant through the spindle and out the end of the cutting tool is a great way to clear chips. Haas Automation’s Through-Tool Air Blast option can be an advantageous alternative.
Blasting coolant through the spindle and out the end of the cutting tool is a great way to clear chips. Haas Automation’s Through-Tool Air Blast option can be an advantageous alternative. This system provides high-pressure/high-flow air through the cutting tool to clear chips and keep the cutting zone cooler. This option is valuable when doing “dry machining.”
Dry machining is possible because many of today’s cutting tools use carbide inserts with advanced coatings that no longer need coolant to lower the temperature of the cutting edge and lubricate the cut area to prolong tool life. The primary cause of tool wear and damage for these cutting tools is re-cutting chips. Blasting the chips out with air addresses this problem. This is particularly beneficial when machining pockets and other internal features, where chips can collect
The Through-Tool Air Blast can also be used to blow chips and coolant from workpieces at the end of a machining cycle. The user simply programs a cutting tool with holes for through-tool air to move over the workpiece–blowing chips and coolant from holes and pockets–before the operator removes the workpiece from the machine. This saves the operator from having to blow off the workpiece manually, with an arm inside the machine and the door open.
The air blast option requires the Haas Through-Spindle Coolant (TSC) option. Because both options use the same internal channels and piping, the operator can switch between the two systems, based upon machining requirements.
JTEKT
More blasting. Less part handling.
