Deep Drilling Without Pecking Or Through-Tool Coolant
These drills enable machine tools to create holes with L:D ratios as high as 20:1 without pecking and without through-the-tool coolant delivery.
Through-spindle coolant delivery has been one of the keys to successful deep-drilling operations on machine tools. Delivering coolant directly from the drill tip via internal passages provides the pressure needed to push chips up the flutes and out of the hole. It enables drilling of holes with length-to-diameter (L:D) ratios as high as 30:1 without time-consuming pecking cycles.
OSG, located in Glendale Heights, Illinois, is a cutting tool manufacturer that offers such drills. The company recognized, however, that many shops don’t have machine tools equipped with through-spindle coolant delivery systems. That limits the L:D ratio they can achieve when drilling water lines for mold bases, for instance, and/or requires shops to use pecking routines to generate deep holes for similar applications. In some cases, shops may even have to outsource that work to a gundrilling specialist. The Helios V-Series drills that OSG developed enables machines to create holes with L:D ratios as high as 20:1 without pecking and without through-the-tool coolant delivery.
There are a few notable design elements that allow these HSS-cobalt drills to effectively create deep holes using only flood coolant. One is a flat flute form that provides an open chip pocket while retaining a healthy web for overall tool strength. Although similar to a parabolic flute form, OSG’s flat flute integrates a small chipbreaker to keep chips short, facilitating their evacuation.
Low-resistance web thinning, another drill feature, reduces thrust by nearly 50 percent when compared to competitive drills to extend tool life, the company says. Its proprietary point geometry minimizes vibration when drilling at very high L:D ratios to reduce the chance that the drill will chip or break.
In addition, the drill’s WXL coating is said to provide good adhesion to the drill substrate and a surface finish with a very low coefficient of friction. The smooth finish of the layered, PVD coating assists chip flow for drilling operations in a wide range of materials. According to the company, the coating offers as much as three times greater wear resistance than conventional coatings.
Form Tapping Improves Tool Life, Costs
Moving from cut tapping to form tapping for a notable application cut tooling costs at Siemens Energy and increased tool life a hundredfold.
Walter Offers New Solid-Carbide Taps for Blind-Hole Machining
Walter’s TC388 Supreme and TC389 Supreme feature patent-pending cutting geometries that fully shear off the root of the chip when reversing, thus minimizing torque peaks.
Walter Launches New Solid Carbide Drill
The DC118 Supreme solid carbide drill provides high rigidity against deflection, superior centering accuracy and four margins with corner chamfers.
